Get access to FPGA I/O from the host VI
Hi!
I'm pretty new in programming FPGA and I have a simple question. I've programmed basic fonctions to send or read signals on digital I/O (7813R).
But I'd like to control which line has to read or output a signal from the host target... I tried to use a "Read/Write Control" but the ressources doesn't appear (they are programmed as controls on FPGA VI front panel)...
Is there any solution ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,594 Views)
Hey Zyl7 - In the host VI, have you opened the FPGA reference and selected either a compiled bitfile or a VI reference?  Do you have the front panel objects on the FPGA VI?  In order to see elements in the Read/Write Control, you must have front panel objects on the FPGA VI and you must properly open the FPGA reference.
Hope that helps!
(3,571 Views)
Hey Bryan,
thank you for your answer ! i confirm that the FPGA reference is opened and the bitfile is correctly loaded. As the other controls, the resources controls are on the front panel of my FPGA VI... In the host VI, i can have access to my other controls (enum, and other numeric controls...) using Read/Write Control but not to the resources...
(3,552 Views)
Zyl7 or Brian,
Was this issue ever resolved?  If so, I'd like to hear the solution because I have the same issue.
Thanks!
(3,492 Views)
Hi!
At the end, I'm using Constant Ressources in the FPGA code... It obliged me to restrict my hardware configuration to fit FPGA programming constraint...
(3,481 Views)
Thanks for your reply, Zyl7!  Sounds like you decided not to have the option of selecting the resource from the Host VI anymore.
I, however, am still interested in being able to select the resource from the Host VI, but as
Zyl7 stated in his original post, I don't seem to have access to it.  Why?  Brian R., do you have any idea?
(3,470 Views)
