Get Serial Settings saved in Max loaded into LabVIEW
Is there an easy way get or retrieve Serial Configurations saved in MAX into LabVIEW?
We have several devices that communicate though RS-232 that require different settings. The connection arrangement of these devices may change from test to test. What  I would like to do is use MAX to determine which equipment is connected to which serial ports, save the communication settings in MAX, and load them into LabVIEW to establish connection. I could write code to allow the user to do this but why reinvent the wheel.
I've attached my list of software incase a newer version might be capable of doing this.
Any insight in this would be greatly appreciated.
Tessa
(3,459 Views)
Accepted by topic author ntaINC
You don't have to do anything to get the serial settings into LabVIEW. As long as you don't use the VISA Configure Serial Port, the settings will persist and you just have to do your reads and writes with the correct resource. Put simply, if you set the baud rate in MAX for Com1 to be 56000, in LabVIEW if you write to Com1, it will occur at 56000 baud.
This has been true for versions of VISA much older than what you show.
Message Edited by Dennis Knutson on 03-12-2010 08:57 AM
(3,446 Views)
Thanks Dennis!!
I thought it would be simple. I have been using the Configure Serial Port vi. I was trying to be too through!Smiley Wink
Thanks Again
(3,428 Views)
Hello from the future! Since this is the main result that comes up from Google, I can add a little info for those, like me, with selective blindness when it comes to actually RTFM.
You have to explicitly set Access Mode to "Load Configured Settings" to get LabVIEW to use the serial settings configured in MAX. Thanks to Steve for finding it. Example code and related discussion in this thread:
https://forums.ni.com/t5/LabVIEW/Can-you-configure-a-VISA-serial-port-in-MAX-to-use-in-LabVIEW/m-p/4...
(118 Views)
