09-12-2008 05:05 AM
I have the similar issue with eastern us time....
If you add 3 hours, that will not balance somewhere else, I had to disable the automatic daylight.....and reboot
the computer(under Vista) to get it working...
I think it it already dicusss in the forum.....
09-12-2008 05:08 AM
09-12-2008 06:13 AM
I disabled automatic DST, actualised time manually, rebooted pc, started LV and the result is: only 2 hours offset.
This is seems not to be the complete solution.
On the other hand, on my Laptop LV always shows correct results, with DST and without.
Manfred
09-12-2008 06:21 AM
Manfred,
the local time matched (of course) the displayed time.
Regarding the time zone info, it seems that it is removed in LV 8.6....or it has to do with my pc working with english OS and english LV......
So if you are not using LV 8.6, maybe you can use the evaluation version of 8.6 to check if the issue persists...
Norbert
