Get Date/Time returns wrong time
I have the similar issue with  eastern us time....
If you add 3 hours, that will not balance somewhere else, I had  to disable the automatic daylight.....and reboot
the computer(under Vista) to get it working...
I think it it already dicusss in the forum.....
Message 11 of 14
(1,097 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=30141&query.id=202141#M30141
Message 12 of 14
(1,094 Views)
I disabled automatic DST, actualised time manually, rebooted pc, started LV and the result is: only 2 hours offset.
This is seems not to be the complete solution.
On the other hand, on my Laptop LV always shows correct results, with DST and without.
Manfred
Message 13 of 14
(1,084 Views)
Manfred,
the local time matched (of course) the displayed time.
Regarding the time zone info, it seems that it is removed in LV 8.6....or it has to do with my pc working with english OS and english LV......
So if you are not using LV 8.6, maybe you can use the evaluation version of 8.6 to check if the issue persists...
Norbert
Norbert
Expert: Geometry
Message 14 of 14
(1,072 Views)
