Get Date/Time in Seconds Function in LabVIEW Returns Incorrect Timestamp
Hi to everybody.
In the following link:
http://digital.ni.com/public.nsf/allkb/0ED147D1507C183F862574BA0070AF06?OpenDocument
is written how to solve the problem found when getting wrong time stamp.
In my application Im saving data in TDMS file; when i read tdms data with Ms Excel, the time is esactly 1 hour ahead if data are read by another computer.
Time is correct if data are read by the same computer that saved tdms files.
So I fellow suggestion from the link, but in Windows registers I didnt find any TZ key.
Im using old Ms Windows Xp profesasional, version 2002, Service pack 2.
Does anybody have some suggestion for this issue?
Thank you alot
Ant
Message 1 of 9
(7,173 Views)
This sounds like a Daylight Savings Time issue.  I've seen that too when moving code from one computer to another and the modified data/time is off by 1 hour.
Message 2 of 9
(7,167 Views)
You have the option to select DST on these functions. Make you you set it to a values that works for your software. Maybe the other computer never got the patch to change to the new daylight savings model.
You could make it look at Windows and determine if the computer is using this offset. I do agree with crossrulz.
Tim
GHSP
Message 3 of 9
(7,160 Views)
Thank you, Tim.
But where to set Daylight saving time? In control panel or in the registers?
Message 4 of 9
(7,149 Views)
It is in the date and time to seconds function. See below:
Tim
GHSP
Message 5 of 9
(7,145 Views)
Accepted by topic author Yixiao-uncle
I tried to use suggestions from forum but all results were unsuccessful.
Anyway I solved problem and I want to share this with other Lv users.
I noticed that in computer used for acquiring and saving TDMS file, the showed time is correct but the time zone was wrong (I live in +1, and pc was set on +0)
The notebook I use for reading tdms data is properly set to +1.
When I aligned time zones, the problem disappeared.
Bye
Message 6 of 9
(7,113 Views)
You should mark your answer as the solution so the everyone knows that it has been solved.
Thanks for sharing your solution with the rest of us.
Tim
GHSP
Message 7 of 9
(7,105 Views)
Hi aeastet,
How did you get this time in seconds, minutes hour etc? I cant see this in timing.
Message 8 of 9
(5,941 Views)
@jooe7788 wrote:
Hi aeastet,
I am not sure that I understand what you are asking. The snipt above can be dropped right into your code and it will work. Just click on the picture and drop it on your block diagram.
I hope that helps.
Tim
Tim
GHSP
Message 9 of 9
(5,935 Views)
