Get Conpane Image Method
Hello
I need to programmatically save the VI icon with the connector pane. I found that this can be done using VI Scripting.
https://zone.ni.com/reference/en-XX/help/371361R-01/lvscript/vi_getconpaneimage
Now I have never used VI scripting and have no clue and no time 🙂
Has anybody an example on how to do this?
(2,423 Views)
Accepted by DAckermann
Go to your LabVIEW install, then open the Options window under the Tools menu.  Go to the "VI Server" category, and in it check the box to show VI scripting functions, properties, and methods.
Then go to the VI you want the connection pane image from, put down a "This VI" VI server reference on its block diagram.  Then wire that reference into an invoke node.  When you click on the node to select which method to invoke, select "Get Conpane Image", and go from there.
(2,418 Views)
Wow. That was easy 🙂
Thanks a lot!
(2,405 Views)
You should mark Kyle's post as the solution, not your own.
Paolo
(2,341 Views)
Oh sorry.I was in a hurry and clicked the wrong button. Can I change this?
(2,331 Views)
Hi DAckermann,
See the message "Options": the same place where you "Accept as solution"!
(2,325 Views)
