Showing results forĀ
Search instead forĀ
Did you mean:Ā
Get Code Of Matlab Node
I wan't to get the code of my Matlab node programatically in the run-time mode just for displaying it.
Thank for all,
Matlab to textMatlab to text
(6,397 Views)
I don't know if this is the best way, but as soon as you have a reference to the formula node, you can read the Formula Expression property. To get the reference, some scripting might be necessary.
cheers!
Remember Cunningham's Law
(6,378 Views)
thank you Peter,
But it cannot work in run time mode.
(6,370 Views)
Accepted by topic author taoufiksmires
Hi taoufiksmires,
the Matlab script doesn't change at runtime so you can copy the text at edit time to a string constant!
Or: place the matlab code in a m-script-file. You can load that file using ReadTextFile to display it in a string indicator…
(6,367 Views)
Or,  use a sub panel!  Oh yeah,  we don't do that often but the sub panel can show the block diagram.  Sized properly just the m node can be shown.  And you can get the bounds at runtime.
"Should be" isn't "Is" -Jay
(6,363 Views)
@taoufiksmires wrote:
thank you Peter,
I'm not sure, I understand. I ran it and it worked and as GerdW said, the script doesn't change at runtime.
Can you please tell me what you want to do, that doesn't work?
(6,348 Views)
thanks to you guys . It's good , Before i build the application i save my script in a file and i read it after.
(6,340 Views)
