Generic File I/O Path Too Long RT Deploy
Accepted by Hooovahh
Go to Options -> Paths and replace the default temporary directory with one of your choosing.
Message 11 of 13
(1,350 Views)
Awesome, that makes the build work without error.  I'll look into making this a standard config for all systems I use.
Message 12 of 13
(1,333 Views)
I think there was a discussion similar to this, possibly on Info-LabVIEW, a while back.  The Mac, like Linux, allows much longer file paths but builds were failing at a temporary path which exceeded the lengths you had trouble with.  It always seemed to occur on "buried" files and folders which no one ever sees or cares about.
I do not recall that anything other than the crude, awkward, and not certain to work work-around you are using was proposed. The suggestion that NI should assure that builds always work if the project path length was within OS limits did not get much traction.
Lynn
Message 13 of 13
(1,303 Views)
