Generating the waveform
Hi everyone
Thanks to those who replied to my message. I am able to transfer the data from optical spectrum analyzer to labview. However, the data is in the form of 2 strings. One of the strings contains the values on the x-axis, ie., the wavelengths and the second string contains the instensity corresponding to the y-axis. How do I generate the waveform in Labview using these two strings?
(2,755 Views)
First, you need to find the delimiter (i.e. the seperator between data values). The delimiter is usually either tab, space, semicolon or comma. Once you know the delimiter, you can use the spreadsheet string to array function to transform the two strings into arrays of doubles. From there you can do whatever you'd like with them, such as bundle them and display them on an X-Y Graph. I've attached a quick example with space delimited strings. It's in LV
Ryan K.
(2,749 Views)
Sorry, meant to say it's in LV 7.0, let me know if you need an earlier version. I should read my posts before submitting them...
(2,744 Views)
Hi Ryan
Thanks a lot. I am also using Labview 7.0.
Gagan
(2,741 Views)
