Generating TTL signal to control external devices
Hi All,
I have created a LabVIEW code to send out TTL signals to injector, spark plug and high speed camera for my optical GDI engine to conduct my ph.d project.
However, somehow although I can observe the signal from the LabVIEW itself, I cannot see the signal from my oscilloscope (Please ignore the pressure profile signal). For your information, when I vary my inputs, the code responds accordingly i.e. timing, duration, etc. of my TTL signal changes as I command.
By using NI MAX, I can confirm that there is no issues regarding the connection.
I am using a LabVIEW 2018 version along with cDAQ-9178 module, and NI-9401 card is utilized for Digital I/O.
Could you please help me to sort this issue?
Many Thanks,
Message 1 of 1
(1,470 Views)
