Using TCP/IP to connect a VI in one computer to another which are connected via same network
Hi all,
We are trying to parse processed  data from a Labview application in one computer to another. We are trying to connect via TCP blocks ,but we only have information about the IP addresses of the two systems. We are unable to understand how to find the remote port or service number and also please let us know if there is any other effective way to send processed data between VIs on different computers.
VI blocks :TCP Open Connection, TCP Read, TCP Write.
(2,506 Views)
Hi anir,
You can/should define the port for your communication channel…
Have you tried to use NetworkStreams instead of plain TCP/IP? LabVIEW comes with ahuge example library and also has examples for using NetworkStreams…
(2,463 Views)
The server should use TCP Listen.vi instead of TCP Open Connection.  You then get to define the port used for the connection.
(2,434 Views)
You should also define what you mean by "parsing processed data".  Do you expect to download a file and work on it locally?
Bill
CLD
(Mid-Level minion.)
(2,426 Views)
The processed data is of data type string and it contains data regarding status of process. This data is  used only for monitoring a process from a remote computer.
(2,415 Views)
Oh, okay.  So if you haven't already, you will have to design a communications protocol to define data start, data stop, and (optional) is what you got what you sent?
Bill
CLD
(Mid-Level minion.)
(2,398 Views)
For the basics which VIs you need have a look at the example "Simple TCP.lvproj" from the NI Example Finder, too.
Regards, Jens
Kudos are welcome...
(2,387 Views)
