Generating LabVIEW Code with SignalExpress Tektronix edition
The oscilloscope behaves well when the program is run from the Tektronix SignalExpress programming environment.  When I try to do the tools>generate code, it does succeed in creating a VI containing the express VI wrapper.  However, when I try to run the code it always comes up with the error, due to the handle identification number being 0.  All I know is that the handle is the identification number that is used to retrieve measurements somewhere in the express vi code. (It cannot be seen due to password protected block diagram)
Picture of error is attached
Any help is appreciated.
Studying for CLA.
LabVIEW, inherit from social media habits!
(2,865 Views)
Hi CDuck,
the problem with the Express VIs is, that they sometimes do weird stuff. At its core, it is just a normal VI that has been constructed by LabVIEW, though. So without seeing your VI I suggest you try these two things:
1) Is there anywhere, where you can connect a reference, number or identifier of some sort? There are 2 Inputs that are unwired. What do they do?
2) You should be able to right click >> Open Front Panel. You'll be asked if you want to convert the VI and if you do, you can look at the VI. Maybe something went wrong during scripting.
Remember Cunningham's Law
(2,840 Views)
The 2 inputs are Log Folder (shouldn't matter because I'm not logging data) and Error in.  I'm wondering if the Tektronix Signal Express is not meant for Windows 7.  I see that the run VI function only accepts LabVIEW 7-8.5 which are all Windows XP exlusive as far as I know.  I'm using LabVIEW 2017, I'd have to use a virtual machine to use LabVIEW 8(?)
Studying for CLA.
(2,787 Views)
Accepted by topic author CDuck
Ok, the express VI is working now.
I changed 2 things and I'm not sure which one fixed it.
1.) I went into the base LabVIEW developer and selected Tools>SignalExpress>Convert Project.  (I did this instead of converting it from the Tektronix SignalExpress API)
2.) Upon converting the project to a VI, I received a warning related to error 7.  I selected Process errors.  It continued on to the VI, and the express VI performed it's function.
Studying for CLA.
(2,780 Views)
