Generating A Sine Wave If True
For this program, I need to generate a sine wave if some variable was true onto the analog output.  This is what this part of the program looks like http://i.imgur.com/JrZFOZY.png
Sine Wave: http://i.imgur.com/dfYtoL6.png
DAQ: http://i.imgur.com/66YLwbH.png
It'll work for a bit but then I get this error: http://i.imgur.com/uL1Fm5M.png
Anyone have a suggestion as to what the issue might be?  Specifically this is triggering whenever TRUE is passed in a second time - it'll work fine for the first TRUE input but then when we get TRUE being input again it doesn't work.
(3,201 Views)
Accepted by mwalk99
In the DAQ, try changing the Generation Mode to Finite Samples.
(3,181 Views)
That worked perfectly.  Thank you so much!
(3,164 Views)
