Generate single sine pulse waveform
I want to generate a single sine pulse waveform (one waveform only). I want to change the amplitude and frequency of the waveform before i generate it. Thanks.
Best wishes. Chan
Message 1 of 26
(6,042 Views)
Hi
check the eamples  that are provided.
ie search for sin waveform will give some hits.
Your are actualy looking for the sin pattern vi
found
on BD palette- signal processing => signal generation=>sinc pattern
xseadog
Message 2 of 26
(6,005 Views)
Thanks. Do you know where i can download a VI example of generating single sine waveform.
Best wishes. Chan
Message 3 of 26
(6,005 Views)
If you check out the examples
 you can modify to suit your actual  requirement.
see attached jpg
xseadog
Message 4 of 26
(6,000 Views)
Thank you very much.
Best wishes. Chan
Message 5 of 26
(5,994 Views)
Do you want to generate it on an analog output channel of a DAQ card?
Message 6 of 26
(5,990 Views)
Hi Dev,
Thank you again for your help. I am using PCI 6120 card. I will explain the test i want to do.
I have two transducers (transmitter and receiver). I will put a soil sample in between the two transducers. The purpose for the test is to measure the travel time through the soil sample. I will generate a single sine pulse waveform to the transmitter and the wave will propagate through the soil sample and collected by the receiver.
Therefore, I want to generate a single sinusoidal waveform to the transmitter transducer. I hope that the amplitude and frequency of this single sine waveform can be changed. Dev, thank you.
Best wishes. Chan
Message 7 of 26
(5,987 Views)
Hi Dev,
Yes, I want to generate the signal using the analog output of the card. Thanks.
Best wishes. Chan
Message 8 of 26
(5,979 Views)
Hi Jason,
Then Function Generator.vi that can be found in examples shipped with LabVIEW should do the job for you
Just fo to search tab in Find examples and type ths VI name to find it
Regards
Dev
Message 9 of 26
(5,972 Views)
Hi Dev,
Thanks. The function generator.vi example generate continuous waveform, but i only want to generate only one wavelength waveform (one wavelength sine waveform with certain frequency and amplitude) when start to run the vi. Do you know where i can find this vi example? Thank you again. Bye.
Best wishes. Chan
Message 10 of 26
(5,970 Views)
