Generate pulse
I'd like to program a VI which generates pulse train. So, I've searched examples and found one as below, also in attachment. Now, I want to see the pulses generated by this example by adding waveform chart in the example. Can anyone teach me how to do?
Jay
(5,128 Views)
Since you use a digital timer output, you would need a analog input with about 20 time the bandwith of your pulstrain to monitor the signal.
Just to show the apearance of your waveform, I suggest to use the 'basic waveform generator.vi' feed it with the same parameters (maybe just some cycles) and then you have a waveform to display.
Greetings from Germany
Henrik
LV since v3.1
(5,096 Views)
Accepted by topic author jeongho20000
you can not see the waveform inside VI, which is generating the pulse,
You have to acquire signal using another acqusition channel and acquire
(5,090 Views)
