IMAQ VISION 7.1
I AM USING WEB CAM TO ACQUIRE IMAGES.
I AM HAVE INSTALLED 'NI-IMAQ FOR USB CAMERAS.'
I AM NOT ABLE TO ACQUIRE IMAGES THROUGH THE 'VISION ASSISTANT 8.5',
AND I've read the "NI-IMAQ_for_USB_Camera_User_Guide. BUT I WAS NOT ABLE TO SEE THE 'VISON' VI IN MY "MEASUREMENT I/O" IT IS EMPTY.
I AM USING EVALUATION VERSION OF LV8.6,VISSION ASSISTANT 8.5. I HAVE ATTACHED THE SCREEN SHOT OF THE GUIDE WITH THIS.
IS THERE ANY PROCEDURE TO FOLLOW FOR ACQUIRING IMAGES FROM THE WEBCAM THROUGH VISION ASSISTANT . PLEASE HELP ME WITH THIS .
ALSO IM IN NEED OF IMAQ VISION 7.1 OR LATER,WHERE CAN I DOWNLOAD THIS??
(6,243 Views)
It is very hard to read all uppercase code, and by the way considered rude to do so in discussion fora, since it is considered like shouting.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(6,229 Views)
thaks for you reply , i will correct myself.
(6,222 Views)
Hi Sailesh,
For your application, you would need vision acquision module 8.6 ... you could download the same from this link:
http://joule.ni.com/nidu/cds/view/p/id/1117/lang/en
Here is an example vi to snap images using usb cam:
https://forums.ni.com/t5/Archive-TKB/NI-IMAQ-for-USB-Snap-and-Save-Image-with-USB-Camera/ta-p/352333...
IMAQ drivers are available at:
https://www.ni.com/en/support/downloads/drivers/download.vision-acquisition-software.html
I am also attaching an example vi:
Please tell if it helps.
Shivam
(6,213 Views)
im using a web cam for my application.
when converting my vison assistant algorithm into labview vi , in the image source setup  box i was not getting the "image acquisition" option enabled.
is there any problem with  cam or the labhview??.
im using vission assistant  8.5 & lv 8.5
(6,191 Views)
