Generate executable file
I am generating an executable file for a client using a developer computer (laptop). However, the executable file on the client’s laptop is running fine except one channel is not reading the same. The input is .216 vol but reading .170.
I am measuring voltage and temperature (8 input and 2 temperature). I am using 6062E card. I did a self-calibration in MAX but still reading wrong.
I would appreciate your help.
(3,498 Views)
Does the channel that is readding incorrectly have an empty channel just before it? A floating channel can cause the channel after it to read incorrectly as the ADC does not have enough settling time. In this case, you can adjust the inter-channel delay or just put a short across the previous channel.
BTW, this happens with E-series cards and not with M-series cards.
    Rob
(3,477 Views)
Thank you for your reply Rob,
Shorting the channels did not improve the reading. It seems all the channels are not reading correctly not one as i stated before. However, discconect the user laptop from the power outlet (120 v) and running it on battery I get the correct reading. I connect all the 8 AIGND together I improved the reading %70.
I am measuring input voltage as NRS from a0 to a3 and a8 to a11. a5 and a6 as thermocouple k type. generated 5 and 0 V from DAC0OUT and DAQ1OUT.
I welcome Any more suggestions.
(3,460 Views)
This is a matter of electrically grounding your laptop.
See http://digital.ni.com/public.nsf/allkb/3C6360322410D7A786256E1D0070C375 .
(3,453 Views)
