Gaussian white noise
Hi, Iam using Gaussian White noise for my work. Does anyone know how many dB SPL for 1 Standard deviation and 2 standard deviation? How to calculate this? I looked at the help but I have no clue to the formula there.
Thanks a lot
(3,842 Views)
Hi , does anyone know how to convert the Gaussian white Noise output to Degrees or radians.
(3,033 Views)
Hi emmu,
Simple solution: use the ConvertUnit function to convert to "deg" or "rad" unit…
In general your question doesn't make a lot of sense. The GaussianWhiteNoise just outputs some numeric values: so your question reduces to "How to convert any numeric value to Degree?". What is your exact requirement?
(3,028 Views)
why would you do that?!
(3,027 Views)
Are you looking at a circular distribution?  [If you don't know what this means, that could be part of the problem you are having].  Instead of highjacking a decade-old question just to reuse its title, you might be better served to start your own question and provide a little more context for us to understand what you are really asking, i.e. what you really don't understand.
(3,020 Views)
