Gaussian White Noise - User Controlled
I was wondering how I could modify the Gaussian White Noise.vi or create a new one that could output a Gaussian signal that could be controlled by varying its mean, std, variance, skewness, and kurtosis. I can change its std but I'm especially having problems trying to control its variance, skewness, and kurtosis.
Thanks!
(3,479 Views)
I've been working with that VI and I don't believe that it has the options you are looking for. You may have to built a custom VI to do this. If you take a look lower down the line of VIs, you will see that they call a DLL to obtain values. You may need to call this with the data dependencies that you want.
J.R. Allen
(3,479 Views)
Well, you have to be careful with the terminology here: Once you add skewness and kurtosis, the distribution will no longer be "Gaussian", right? Basically, you want to generate random data, that, after infinite sampling forms a predetermined (non-uniform, non-normal) probablility distribution shape.
You probably could generate a inverse probablility function from your desired distribution, then feed it with the 0...1 uniform distribution.
As an example, I show the image of a VI that uses the Inv-normal function (found deep in the probability palette) to generate gaussian distributed random noise from a uniform noise distribution. I am sure you can adapt the same idea to generate data that conforms to your desired statistics.
(3,479 Views)
