Gauge
Hello all,
I need some pointer how to change the gauge number to something like the right picture. Thanks!!!
(3,379 Views)
Search for "custom guage" and or "compass" for more info.
YOu can use the drag tool to drag the max to overlap the min to get a full circle.
The numbers can be specified manually using property screen or using methods to do the same.
Ben
(3,366 Views)
Look at message 159 in the Micro-Nugget thread.
Lynn
(3,346 Views)
like ben said...rt click gauge and goto properties, scale tab and check "inverted", then goto text label and empty string on the 360 value to not appear.gauge_VI_FP.png
(3,330 Views)
Dear Apok, Thanks for the VI. Is it possible for you to post it in Labview 2009. Thanks!!! 🙂
(3,301 Views)
no problem...Smiley Wink
(3,297 Views)
