GPU
Hi
How do I implement a simple for loop in parallelism on GPU. I can implement it on the CPU but I need to use the GPU for Parallelism.
Ritesh
(3,992 Views)
Ritesh,
do you have the GPU Analysis Toolkit? If so, do you have a NVIDIA CUDA graphic card or something else?
Norbert
Norbert
Expert: Geometry
(3,975 Views)
Hi yes I got the GPu analysis toolkit for nvidia
(3,958 Views)
Ritesh,
did you search for examples for this? There is also a very general tutorial on this. Have you read it? Did you check the links in the "next steps" section?
If you run an example using the GPU functions, do they work?
thanks,
Norbert
Norbert
Expert: Geometry
(3,946 Views)
Hi
Yes I did look through and the examples but nothing to help me get started. My goal is to implement IMAQ pattern matching a 100 or more times in one iteration (On the GPU). But I also want to start small and by doing a simple calculation on the GPU
Ritesh
(3,926 Views)
Hi reigngt09,
Here are some discussion forums and other resources that might help you get started with GPU Analysis toolkit.
https://forums.ni.com/t5/GPU-Computing/Medical-Image-Processing-on-a-GPU-from-LabVIEW/m-p/3415613#50...
https://forums.ni.com/t5/GPU-Computing/For-what-applications-are-you-using-LabVIEW-and-GPUs/m-p/3407...
http://niweb.natinst.com/confluence/download/attachments/54200285/NVIDIA_CUDA_Programming_Guide_1.1....
Let me know if it is helpful
Ryan
Applications Engineer
(3,904 Views)
