GPIB install
Hi all
I have many problem for install GPIB/ENET.
My configuration :
workstation
GPIB/ENET
DC source 0-20 volt 66332 A
1 oscilloscope infinium ref:54835A
1 pulse patern generator ref:81130A +81132A
GPIB box is alive but no device are find.
Can you help me ?
(3,090 Views)
What OS are you running? I would suggest referring to http://www.ni.com/support/gpib/versions.htm to make sure that you have the latest driver installed. Once verified, do the GPIB test utilities (Getting Started Wizard, ibtsta, ibdiag, etc) recognize the ENET? Are you able to find listeners at the instruments' addresses using IBIC? Make sure that you keep the bus to 488 specifications. I would suggest, for testing, that you connect only one instrument (powered on) to the ENET with a maximum of 2m of cabling.
(3,090 Views)
