GPIB in a LabView-application running as EXE-file does not work
I try to connect an Instrument over GPIB and I use VISA from a Windows2000 PC without LabView installed. The GPIB-card is not from National Instruments. The Programm is running as EXE-application. What else do I have to install beside the EXE-file to access the Instrument?
(2,891 Views)
NI_VISA.
Ben
(2,891 Views)
Since the GPIB card is not from NI, you will need to install the other vendor's VISA (or the same I/O functionality that you needed on your development machine) onto the target machine.
Dan Mondrik
Senior Software Engineer, NI-VISA
(2,891 Views)
NI-VISA is not enough. It still doesn't work. The Programm VISA-interactive-control does not find the GPIB-card.
(2,891 Views)
