GPIB Coding for the HP4191A Impedence Analyzer
Hi everyone,
I am trying to use Labview and an HP4191A Impedence Analyzer to make some basic frequency measurements. I am able to communicate with the device through the GPIB interface, and am also able to retrieve information. However, I cannot successfully perform a sweep or even move the measurement marker so that I can read the impedance/phase information at frequencies other than the default one set on the instrument at the time I perform the measurement.
Because the 4191A is so old, I'm got my GPIB code from the programming manual for the HP4291A, which is supposed to be compatible with the 4191A. I suspect that this difference might be causing my problems.
In particular, after setting up and initiating the instrument, I am initiating the measurement and reading it as follows:
'INIT;'
'DISP:TRAC:MARK:ALL:STAT ON;'
'CALC:EVAL:Y1:XPOS 300MHz;'
'CALC:EVAL:Y1:DATA?;'
which comes straight from the programming manual. In the code above, 300 MHz is an arbitrary frequency. However, rather than being returned the data at 300 MHz, I am returned the data at whatever frequency the analyzer is currently set at.
If anyone has worked with the 4191A and/or GPIB before, can you verify whether my GPIB strings are valid or not?
Matt
(4,049 Views)
 Sorry, that last line of code there is supposed to read:
'CALC:EVAL:Y1: dATA?;'
The forums emoticons took over for a bit there 🙂
(4,042 Views)
I have not worked with that instrument, but the Agilent web site has the operating and service manual here. It's 84MB, so I hope you have a fast link.
(4,038 Views)
Accepted by topic author Matt C.
I have worked with the 4191A and, as I recall, the commands are nothing like any other instrument I have seen.  You really need the manual.  I think the 4291 would probably take the old 4191 commands, but the 4291 ALSO has new commands.
IIRC, the sweep parameters were something like this:
A=(start freq)
B=(stop freq)
C=(step size?  or was it number of pts?)
Good luck with it....
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(4,035 Views)
Matt - you're right, the commands for the 4191A are completely different from the 4291 - probably because of its age. I went through the manual before, but when I saw their GPIB section, the strings were so convoluted and so unlike anything I've ever seen before that I assumed it was referring to something different. When I gave it a try, though, it worked fine.
Guess you never know until you try!
Thanks for your help guys.
(3,988 Views)
Has anyone done anything on interfacing with the 4191A since Matt C's last post?
(If not, what would creating a driver for it entail?   Should I be looking at doing it with LabView or something else?)
Matt C. : Would you mind posting the code you used on the 4191A?
Thanks!
(3,784 Views)
