GIF Reader VI
Hi Guys,,
I am currently developing a vi that gets the output screen dump of a emc analyzer.
the problem i have is the output is in GIF format from the gpib recieved vi. I want to read it to be viewed in the
front panel but i dont have a read gif vi..
is anybody have one on hand?
thanks
Message 1 of 11
(8,000 Views)
See here.
If it works give Mike some Kudos.
Ben
Message 2 of 11
(7,996 Views)
i cant open it, i'm using lv 8.2
Message 3 of 11
(7,988 Views)
Here is the LV 8.2.1 Version.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 4 of 11
(7,963 Views)
i have some errors. pls see attached diagram.
the output from the instrument is a string data, i converted it to a binary file then to be read as a .gif file but i got some errors.
do you have any information regarding the error:
error 50001 : This version is not yet supported!
error 50002
Message 5 of 11
(7,955 Views)
Although the data is binary you have to use the "Write To Text File" function and make a right click and uncheck "Convert EOL". The icon will then look the same as in the palette.
Here is another discussion about getting a gif-file from an instrument and save it to a file.
Message Edited by waldemar.hersacher on 10-22-2008 08:58 AM
Waldemar
Message 6 of 11
(7,932 Views)
i am using lv8.2
the example is lv8.5
Message 7 of 11
(7,914 Views)
i already got it working in saving the screendump to a .gif file in the host pc.
what i need now is how can i display it in the front panel
Message 8 of 11
(7,911 Views)
hi Waldemar,
i tried to use the vi you have sent.
I only got this, please see attached file.
i didnt get the whole picture.
but if i view the file in other picture viewer i can see the complete screen dump.
Message 9 of 11
(7,899 Views)
cmdrb,
look at the Gif.Example.vi which is part of the zip-Archive.
You can see how to resize the picture indicator and you have to use Index Array to get just one picture.
Waldemar
Message 10 of 11
(7,878 Views)
