Front panel doesn't show
I have a vi (1) that calls a subvi (2) when I press a button. This subvi (2) calls the vi (1) again when I press another button. I have a event structure for this button (button of the subvi (2) ) where I set to false FP Open property for the vi (1) and then I call by reference this vi (1) and I do an invoke node (run) to show the front panel of it but it doesn't work. Why?
I post a image.
ToNi
(2,772 Views)
Hello tonitpp:
Unfortunately, the "Run VI" method only executes the vi and it will not open the front panel. 😞
If you want to open the front panel, use the "Open FP" method, which is also located on the same class. 😉
I hope this helps.
(2,716 Views)
