From dynamic data to string
I would like to convert my dynamic data (4 channels and time) to sink of string (I am using UDP Write).
I tried to build an array, and then use Nnmber to fractionnal string, but I can't wire the two, because it's 1D array of string.
Thanks for your help!
Sarah
Images intégrées 1
(5,650 Views)
Use a for loop, input the array of numbers as auto-indexed, input that to the convert function, and output the result as an auto-indexed tunnel. The result will be an array of strings.
(5,645 Views)
It is already in a for loop. And the input of the UDP is a sink of string..
And I don't know what is an auto-indexed tunnel
(5,641 Views)
Accepted by sarahdan
did you check Array To Spreadsheet String Function
(5,633 Views)
Attach your VI.
And if you don't know what is an auto-indexed tunnel, then take the tutorials.
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(5,627 Views)
sarahdan wrote:  I am using UDP Write
And what is recieving the data on the other side?  Another LabVIEW program?  A microcontroller?
(5,618 Views)
