05-15-2020 07:41 PM
Thank you so much, I will try this and update you.
05-17-2020 10:31 PM
Hi ,
Using r/theta to complex now I don't get anything in time domain.
05-18-2020 09:45 AM
@Alias110 wrote:
Hi ,
As I said earlier, your data is incomplete. Your CSV has wavelength and magnitude, to invert a FFT you need two pieces of information. Look at the example below, read up on the FFT.
mcduff
05-18-2020 01:58 PM
Thanks, but that's all I can get from a spectrometer.
So, let's say I assume my spectrum is close enough to Fourier Transform limit. Since the constant or even linear phase does not change the pulse and only shift it in time domain, to perform the program, how about adding a linear phase in the 3rd coloumn of the CSV file ?
I added that, but the out put (in time domain) was range of 3 pulses.
The spectrometer does not produce any information about the phase. I like to know your thought for this.
05-18-2020 02:17 PM
This is out of my knowledge.
You can make some assumptions, but the spectrum you obtain will not be unique. For example assume you have two sinusoids in the time domain. The power spectrum gives two delta functions at their respective frequencies. Without knowing the phase between them, the time series I construct may not look anything like the original signal.
I suggest looking for algorithms that make clever assumptions in order to better guess your real signal.
mcduff
05-20-2020 08:25 PM
I haven't found solution yer. Does anybody has other suggestion? Should I make an extra third column in my data? In Matlab I have done this and the solution consistent with mathematical models.
05-20-2020 10:26 PM
Look at the example below.
Look at the difference between the original signal and the one where the phase is set to 0. The one where the phase is set to 0 STILL shows two sinusoids but the exact relationship between them is different than the original signal. You need to decide if you are willing to live with that. Without a complete transform you can only guess.
2019 version attached, play around with it to see what you are willing to live with. What you are asking is impossible to determine. You are asking to put something back together without having all of the pieces or even knowing what the missing pieces look like.
mcduff
05-22-2020 08:34 PM
Before accepting this as solution, I just have a quick question: I do not want to underestimate the power of Lab View, but isn't this a weak spot? I mean if I have a spectrum including only amplitude vs frequency, I can get its FT in Matlab, for example, which shows the graph in time domain. There, I do not need to come up with making some extra column just for technical reason. But here I have to do so...
Again, this is just to further explore as I am very new beginner in LabVIEW.
05-22-2020 09:23 PM
I am not sure what you are doing in Matlab because you haven't posted the code.
This is NOT a LabVIEW problem, please read up on the FFT and its properties.
Maybe your original Matlab program has both pieces of information, maybe you are doing the FFT, not iFFT, of a series and you only need one column, BUT this is not a LabVIEW problem.
The FFT and iFFT are not the same thing in Matlab; make sure you are using the correct function. See this link
mcduff
05-22-2020 10:26 PM
Can you tell us more about the spectrometer you're using to collect the data? I find it extremely hard to believe a spectrometer wouldn't give you phase data.
