Formula node, keep getting errors
I am trying to integrate a formula node into an array, I keep getting errors and don't know why. Any ideas?
Thanks!
(3,833 Views)
X is a 2D array but you're trying to index it as a 1D array. You're also missing a semi-colon at the end of that statement....and y needs to be indexed since you want a 1D out.
(3,829 Views)
Accepted by sofiakyle
That is a better attempt.
The problem is that you only defined your output y array to be a 1-D array.  And your math on the input array is also acting like it is a 1-D array.
See the attached modification.
But your formula is simple enough that doing it in real LabVIEW code is easier and you don't have to deal with syntax problems of the formula node.
(Note, since I don't have your data, I couldn't run this, so it is possible there are errors.)
(3,824 Views)
