Formula Node or problem
I'm having a problem using the formula node.
The output variable is always 1, but I notice that if the code was:
if(N != 1)
L = 1;
else
L = 0;
The program work ok.
Sílvia
(3,783 Views)
Your screen shot shows if(N!=1||N!=2).  That is if N is not equal to 1 OR N is not equal to 2.  Well, since N can never be equal to 1 and 2 at the same time, of course the statemenet always evaluates to True.
If N=0  True OR True = True
If N=1  False OR True = True
If N=2  True OR False = True
If N=3  True OR True = True
(3,777 Views)
Silvia,
you must inver the logic because... N is always different from 1 OR different from 2
Try with:
if ( N == 1 || N == 2)
L=0;
else
L=1;
Cheers
(3,771 Views)
I verify it after...
(3,765 Views)
