Formula Node Error
I am entering this formula :
z = -10*log((10**((x)/10))-(10**(-(y)/10))); in the formula node.  An error is displayed. Error on line 1 is marked by a '#' character: "... = -10*log((10**((x)#/10))-(10**(-(y)/10"    Formula node: array indexing expected. Did not get it. Please provide me with a solution
(4,437 Views)
Hi Chhavi,
Did not get it.
So you wire an array to your formula node - and don't get the error ""array indexing expected"?
Why use a formula node at all?
Because of famous polymorphism you can easily replace the controls/indicators by arrays…
(4,423 Views)
A for loop around the expression node would work too.
Indeed, no reason for the FN...
(4,374 Views)
You can process arrays in the formula node, but it's quite a hassle
(4,363 Views)
I abhor the formula node for the simple reason that you have no chance for syntax error using native math primitives instead.  (My typing is, well... bad.)  😄
Bill
CLD
(Mid-Level minion.)
(4,322 Views)
I do like expression nodes for simple scaling, like going from mm to m and vice versa.
A typical bug with the formula node and expression node is related to the fact that we use commas as separators over here. And when you use a number with a comma, you can get a valid expression, but not a valid result:
y=x*12,34;
This results in y=12 for x=1, not y=12,34!
(4,302 Views)
Moreover, you can't inline a subvi, which has an expression node or formula node within
that's the main reason we use those structures only for prototyping
here's my favorite:
http://zone.ni.com/reference/en-XX/help/371361R-01/lvinstio/degrees_to_radians/
(4,297 Views)
