Formula Node Calculation Issues
I'm trying to make an array where the output is defined by the formula 25*(2^x) where x is the input variable, with integer iterations from 0 to 7.  To do this, I made an formula node and put it in a for loop.  Unfortunately the (^) symbol is not working right for the calculation.  I tested it simply with x^2 and this did not work, while having x*x returned the correct values.  Instead of outputting the correct values, it outputs seemingly random integers.  Anyone know why?  I am new to this software so I apologize if this this a common issue but I could not find help anywhere else.
(3,180 Views)
Accepted by topic author DK08
The LabVIEW Help does explain the allowed operators (Help>Formula Nodes>Precedence of Operators). The '^' is a bit exclusive or. A '**' is exponentiation.
(3,176 Views)
Thank you so much, I thought I was going crazy.
(3,172 Views)
If you use the numeric primitives rather than a formula node, craziness can be avoided (well, sometimes).
Lynn
(3,163 Views)
