Format for writing arrays to binary files
I'm trying to write to a binary file as a first step in understanding how the saved formats work.
Right now, I have two vi's, one writes a single double to a file, and the other writes a 1d array of doubles to a file.
When I read these files into MATLAB, observing the correct format, I successfully get my single double scalar back, but not the array of doubles.  The array comes from 10000 samples of a sin waveform.  I can observe that the output of the sine wave is correct via a waveform graph, and a waveform chart plugged into the Y values of the sine waveform.
I use the same commands in MATLAB for both:
fd = fopen('output.bin', 'r', 'b');
input = fread(fd, inf, 'double=>double');
fclose(fd);
Attached are the two variations of the vi.
(5,096 Views)
Accepted by topic author justynnuff
By default LabVIEW writes the size of the array to the first few bytes of the file. I am not sure whether MATLAB interprets that size information. The Write to Binary File has an input to control the saving of the size information.  Try a boolean False wired to "prepend array or string size?"
Lynn
(5,089 Views)
Like a charm.  I must have misread that as it defaults to false, thank you.
(5,084 Views)
