Form Unload
Hi all, 🙂 I tried searching for an equivalent of form unload for VB but from what i could understand i couldn't find anything. In my program i am opening serial ports, etc. and i want in case the user/system does not close the program properly during operation to have an event type structure(for example) in order to close the ports so they can release the resources and be able to run the program normally later on. Is there an equivalent function or way to form unload like in VB for labview? Cheers
(2,943 Views)
Accepted by topic author Malakeh
There's a Panel Close? event for the VI. Normally, though, you wouldn't need to use this, as you can simply design the VI so that code runs after your main loop completes.
(2,938 Views)
Hi Smercurio_fc, Thanks for the response, I want to avoid having to click stop to then close the program that's why i wanted the event :) Thanks again 🙂
(2,930 Views)
