Can a US Digital DAQ be used in LabView?
Hi I am using a US Digital USB4 DAQ to read three encoders. How do you make this USB4 an input into labview?
(2,945 Views)
Did you bother to look on their web site? They have LabVIEW drivers. http://usdigital.com/support/software/usb4-software
(2,942 Views)
I did, however when I try to run them, LabView gives me errors. I am running LabView 10 and the drivers are for 8.6. Do you think this could be a problem?
(2,939 Views)
What errors?
(2,937 Views)
Dependency loaded from new path (3 warning affecting 2 callers)
(2,935 Views)
It says warnings, not errors. It's just telling you that the VIs were saved with a certain path to the DLL, and you had the DLL in another location. As long as the Call Library Functions are pointing to the DLL and don't show a broken run arrow you're fine.
(2,929 Views)
Ok. Let met take another look at them.
(2,925 Views)
