‎04-16-2008 07:23 AM
‎04-16-2008 07:30 AM - edited ‎04-16-2008 07:31 AM
The number of bits is related to the resolution of the sampling and may not impact robustness.
There is a calculation that you can do to determine the one more appropriate for your measurement. It is based on the voltage range (after signal conditioning). You may do a search in the Knowledge Base, since I do not remember it (although fairly simple)...
Can you define what you mean by "robust"?
‎04-16-2008 08:54 AM
‎04-16-2008 09:15 AM
‎04-16-2008 10:32 AM
I agree with Lynn.
The best place to start (if you are acquirinf signals) is to improve the signal conditioning. It is best to work with a clean signal at the source than to try and clean it up using filters. Using filters may (will) also filter out desired signals.
So get rid of the noise at the sourse. Noise = any unwanted signals. Lynn provided very good recommendations in his 2nd paragraph.
RayR
