For / While loop first execution
@cwhw112 wrote:
Since someone referenced how you can expand down the left side of a shift register (to utilize values from previous loop iterations), I assume the FB node delay must then be number of iterations where no output comes from the FB node
If you really want to grasp these concepts, I recommend doing your own breakdown.
We can explain the model of the FBN (or whatever concept) but the best way to make it stick is to scrutinize the concept over a few sessions (test, let it sink in, test, etc.). Than, for optimal results, explain it to someone else.
After all, this is all described in the manual too: Feedback Node - NI
However, that will tell you all the options, but you won't grasp the ins and outs until you play with it. A lot.
Message 21 of 21
(411 Views)
