For Loop conundrum
@Ben wrote:
The dangling participal (the unwired control) COULD imply other than starting at index "0".
Ben
Simply replacing my hard code 0 with the dangling Index control would take care of that problem.  Of course there are a lot of what ifs.  What if the second array length and the index extends beyond the length of the original array.  I'm not trying to write an all inclusive code that will match all possible scenarios.  I just wronte what matched the original post.  Please feel free to expand the code as you see fit.
- tbob
Inventor of the WORM Global
Message 11 of 16
(1,622 Views)
I love guessing games so I will play along.  My guess is that the OP originally had the Index Control wired to the For Loop and the rest (second for loop, array size) was added during the fog of debugging.  I am guessing there is an array of indices and values and the goal is to replace certain elements. Only thing stopping that For Loop is an empty array or two as previously guessed.
If I insisted on using Globals I would at least move them outside the For Loop and use a Shift Register inside.
My final guess is yes Alec, you were drunk and you haven't replied yet because of a hangover.
Message 12 of 16
(1,602 Views)
I nominate this post to be in the Funny Threads thread.
- tbob
Message 13 of 16
(1,590 Views)
tbob wrote:
According to the OP's original post, he wants to replace array elements starting at 0.
No, he tries to "insert into array", not "replace array subset". Look at the icon!
While we are all still guessing about the purpose, the (near) literal translation of the rube goldberg code is a simple build array in concatenate mode.
Here's a draft.
(Of course we don't know the size of the "mark" array, so most likely adjustments need to be made).
Message 14 of 16
(1,571 Views)
You're right.  After a while all these icons start looking the same.  Is it Friday yet?
- tbob
Message 15 of 16
(1,553 Views)
@tbob wrote:
@altenbach wrote:
Yes if "Virtual Fridays" count. Smiley Tongue
Ben
Message 16 of 16
(1,520 Views)
