03-22-2022 11:55 AM - edited 03-22-2022 12:12 PM
Hello, I am working on a project and in this one I regularly use loops to perform various operations and in particular calculations on elements of tables of variable dimensions.
Everything works perfectly but the execution time is too long and I want to improve it. This is where I learned about "For Loop Parallelism".
However, after multiple tests I realized that this feature did not always improve the execution time of my loops. (see the attached VI)
(Worth It)
(Not Worth It)
Is there a way to know in advance the cases in which the parallelism will be profitable and which it would not be the case?
Thanks in advance.
03-22-2022 12:25 PM
I think VI Analyzer can help there.
03-22-2022 12:47 PM - edited 03-22-2022 12:50 PM
There is a parallelization overhead to split the problem and reassemble the results. Do you really need 5D arrays? Why all these coercion dots? You did not even disable debugging!
If the task inside the loop is small, the parallelization overhead dominates, as in your case. Parallelization helps if each iteration requires significant effort.
03-22-2022 02:13 PM - edited 03-22-2022 02:14 PM
Hi coco,
despite the other good advices you already got you also should try to use NO LOOPS at all - atleast benchmark such possible solutions:
I agree it most often doesn't make sense to work with 5D arrays.
And you should try to avoid coercion dots on large arrays too - even though there is one in my added code…
03-22-2022 02:33 PM - edited 03-22-2022 02:36 PM
In my experience, parallelism is useful only if the content of the loop takes significantly longer to execute than the overhead to manage the parallelism.
For example, signal analysis, accessing multiple instruments are situations which are benefitted from parallelism.
As a rule of thumb, if the loop content takes ~5ms or more to execute, you will be benefitted from enabling parallelism.
03-22-2022 03:03 PM
Ha! I actually played with the same ideas earlier. One blemish is the need to allocate that huge boolean and integer array, but the multiplication can take better advantage of SIMD instructions. (Hard to tell what the compiler does behind the scenes).
In any case, these indicators need to go behind the sequence frames because updating them with these gigantic amounts of data suck CPU from the timing, potentially interfering with reading of the last tick:
No, an empty frame should not take 70ms!!!!!
03-23-2022 03:01 AM
Thank you for all your answers.
@billko I will look at the VI Analyzer.
@altenbach @GerdW Unfortunately most of the operations I perform need to use 5D arrays and I can't usually not use a loop like in the first attached VI.
I apologize for the coercion dots, I made the VIs in a hurry and I didn't pay attention, but in general I avoid them, I read that it could slow down since it creates a copy of the data.
@santo_13 That was my understanding, but I was just wondering if there was a tool to predict in advance if the parallelism would accelerate. For the moment I test my loops one by one to see if the parallelism speeds up or slows down my system but the idea was to avoid all that.
03-23-2022 03:16 AM
Hi coco,
@coco82 wrote:Unfortunately most of the operations I perform need to use 5D arrays and I can't usually not use a loop like in the first attached VI.
Why do you need 5D arrays? (Do you really need them?)
In my experience LabVIEW can handle 1D/2D arrays much faster than 3+D arrays. Is there a way to transform your 5D problem into a 1D memory presentation?
03-23-2022 08:12 AM - edited 03-23-2022 08:13 AM
@GerdW wrote:
Hi coco,
Yes, maybe some timely concatenation instead of autoindexing could help here.
03-23-2022 08:25 AM
Unfortunately, there is no tool to predict that but with sufficient experience, you might be able to make a good guess. Again, even if there were a tool, the tool would not know anything about the runtime data sizes that might affect the execution time, for example, an FFT operation with just 2 elements vs 1 million elements, this is something the tool cannot forsee.
Everything boils down to what your real application is and optimize for that.
