Float to HEX and back to float(bytewise)
  1. Float val=12.961126;
4BYTES HAS BEEN ALLOCATED
12.961126
2.
1 BYTE
1 BYTE
1 BYTE
1 BYTE
3.
THEN CONVERT TO HEX FORMAT (BYTEWISE)
NOTE:rough value taken for explanation
NOTE:WHOLE 4 BYTES ARE NOT CONVERTED TO HEX.HERE BYTE BY BYTE IS CONVERTED TO HEX
4B
56
A4
FF
4.
                                                NOW GETTING BACK THE ORIGINAL VALUE.
This im facing while getting float value from visa read.any HELP
kudos welcome
Message 1 of 30
(11,910 Views)
One way to convert is to just use type cast. It works also in the other direction (Byte array to Float). But it seems I don't get your numbers.
21830iC2075E029EB1235B
EDIT: If you need it in string format use the corresponding conversion function:
21832i87F3524382458409
Hope this helps.
Message 2 of 30
(11,896 Views)
Hi dan,
      I knew 1st ill be receiving this post.
      im looking for seperate byte by byte of float to hex conversion and viceversa not the whole float conversion.
 no problem with that.
I want the same thing to be done in byte by byte.
kudos welcome
Message 3 of 30
(11,882 Views)
I Cant able to open your attachment. please give me a snapshot of your attachment or a doc which can open with word 2003.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 4 of 30
(11,871 Views)
Did you look at the 2nd image in my post?
This returns an array, so you can operate byte-wise.
Message 5 of 30
(11,861 Views)
if I understand your problem, you need to use the "String to Byte Array" node  to convert the raw string to its byte representations to send them via VISA.
@ Baji: Problems with docx are to be solved here: http://www.microsoft.com/downloads/details.aspx?FamilyId=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displa...
greets, Dave
Greets, Dave
Message 6 of 30
(11,859 Views)
hey Dan,
       send me the vi of what you are getting
kudos welcome
Message 7 of 30
(11,849 Views)
Here you are.
Message 8 of 30
(11,846 Views)
Hi baji,
vi attached of what we were discussing
kudos welcome
Message 9 of 30
(11,842 Views)
Hey dan,
       only number 41 matches others wont.
see the vi i have attached
kudos welcome
Message 10 of 30
(11,832 Views)
