03-17-2021 04:23 PM - edited 03-17-2021 04:25 PM
@GeorgeLiu308 wrote:
Still no explanation for why you posted this code? You don't need the loops at all.
03-17-2021 04:49 PM - edited 03-17-2021 04:50 PM
... and you still did not notice that "boolean to 0,1" converts to I16, causing an up-conversion of all later data and the mentioned coercion dots. All this has been solved many times in the forum. Please only post if you think your code is significantly better. In that case you need to explain why. Just plastering an image without comments is pointless and not helpful. We don't even know if you offer it as a solution or if you require help because it does not work as you expect. Feel free to ask the moderator to remove your posts.
03-18-2021 03:53 AM - edited 03-18-2021 03:56 AM
@omprakash wrote:But do have any idea why im not getting required HEX(414F60C6)
instead im getting HEX( 417F67BB) while doing serial VISA read.
NOTE:char,integer and long are obtained correct.
If that is the data that is received, no conversion will fix it.
414F60C6 converts to 12.9611
417F67BB converts to 15.9628
If you're absolutely sure the device should send 414F60C6, then it seems to me there's a problem with the device. Or with your understanding of it.
Why do think 414F60C6 is required? What should this value be? Why can't it change? What is the device your reading?
If the device has a 'hold' button, that might only freeze the display, not it's internal value. So the display may show you 12.9611, that doesn't mean the returned value is 12.9611.
03-18-2021 07:56 AM
Hi Wiebe,
The message you are replying to is from the original poster from 11 years ago. This is a zombie thread.
03-18-2021 10:27 AM
@RavensFan wrote:
Hi Wiebe,
Thanks.
Makes me wander why any of us responded...
03-18-2021 10:46 AM
No problem.
Most of the recent responses were a back and forth with a long time forum member, but first time poster who revived the thread with a diagram that he thought was "better".
03-18-2021 11:02 AM
@RavensFan wrote:
No problem.
I think those new posts came out of the blue.
AFAIK it wasn't the first time poster (there's no "author" icon), and the intent is totally unclear as well.
03-18-2021 11:08 AM
wiebe@CARYA wrote:
@RavensFan wrote:
No problem.
The resurrection of this thread was done by somebody who currently has a total of 2 posts, both of which are in this thread.
03-18-2021 11:41 AM
wiebe@CARYA wrote:
@RavensFan wrote:
No problem.
I didn't say he was the original poster (now "author" based on the new icon that just got release in the past couple days.) Just that his first posts were in this thread. Even though he had registered on the forums a long time ago (back in 2015), thus a long time member.
Basically it made no sense for some who had been on the forums for 6 years to choose an 11 year old thread to post into for his first message with a "solution" that was not better and had no context as to why the thread should be revived after 11 years with his message.
I think we can now let this thread go back to Rest In Peace.
03-18-2021 12:40 PM
@RavensFan wrote:
wiebe@CARYA wrote:
@RavensFan wrote:
No problem.
Ah, OK. That makes sense.
