Flat sequence structure
@John1982 wrote:
Hello. Weird [...]
Smiley Very Happy  Auto-correct?
Jim
Message 11 of 17
(1,256 Views)
auto correct?
Message 12 of 17
(1,238 Views)
Intially I i put 2000ms but it was too short to see the effects to i increased the time.  But do u have any idea  why my drone doesn't rotate anti/clockwise 360degree.. Hmmm parallel? What will happen? 😕
Message 13 of 17
(1,237 Views)
Hi John,
I don't know why your drone doesn't react on your commands. I don't have such a drone and I can't test your VIs...
Message 14 of 17
(1,212 Views)
I'm guessing you're using the AR Drone Toolkit. They have their own group and you may have better luck there.
Are there example programs where you got the Control Drone.vi?
1. Remove all time delays from your subvi's.
2. Replace the wait vis with my attached vi and use the error wires to locate the delays. (OK it's not mine I grabbed it from Peter Blume. Get his book LabVeiw Style Guide it has lots of great stuff)
3. Remove the flat sequence structure.
Then troubleshoot. Does true=Take Off? If it does you wil have to click the button on. In your sub vi's are you using the correct constants in the cluster.
I assume the sequence should be
Start Motors
Climb x feet
Hover
Yaw Left
Yaw Right
Climb - x feet
Stop motors
It looks like your missing some steps.
Norm
Message 15 of 17
(1,107 Views)
viper,
You are responding to a 2 year old thread. Why?
Message 16 of 17
(1,094 Views)
Coulda swore it was on the 1st page. OOps
Message 17 of 17
(1,086 Views)
