Flashing Arduino file using labview
This is working...
Actually I have to run the commands (like upload, compile..) from the folder where arduino is installed...
Thanks for your replies...
Thank you very much....
Message 21 of 26
(1,718 Views)
Hi i tried the very same thing, but i am not able to flash code to my arduino uno.
I am trying to flash BlinkwithoutDelay code to arduino uno using System Exec Block.
I have shared the standard msg I am getting, can you help me with this.
Message 22 of 26
(1,490 Views)
The error message tells you that the operating system cannot find the "arduino" program.
I would recommend skipping LabVIEW at first:
Open a Windows command prompt (Win+R, "cmd") and get the command working from there.
After you get it right, copy and paste it into LabVIEW.
You might also want to check the "Dir" variable. I am almost certain that it does not do what you want it to do. Why did you wire it there?
Message 23 of 26
(1,482 Views)
I tried the same in command prompt, but still not working. I am not sure about the command line what i am using, can you give me format of command line which I can use in my windows command prompt.
Message 24 of 26
(1,469 Views)
This seems like you first need to sort out your arduino IDE and your problem is not (yet) LabVIEW-related. A link to more documentation has been posted here, in https://forums.ni.com/t5/LabVIEW/Flashing-Arduino-file-using-labview/m-p/3796070#M1071207
I believe that the documentation at arduino.cc is also quite extensive.
Message 25 of 26
(1,463 Views)
you can find more command line from arduino IDE with configure on arduino preference and checklist of compilation and upload, after that you can compilation your code in arduino IDE and find status compilation, you will get information like this :
Message 26 of 26
(1,367 Views)
