First Iteration of the most inner loop not behaving
Refer to the code,
The most inner loop doesn't behave on the first iteration,
I'm currently doing a test with laser, but with the first iteration, laser always returning the same value.
After first iteration, it then actually send command to laser and get the reading from it.
I'm curious on why it always happen on the first iteration and ideas to fix it.
Also, any suggestion on how I can clean up my VIs better.
Message 1 of 9
(1,642 Views)
It might help if you save back to LV20... More people (incl. me) will be able to look at your code.
Some embedded, additional images might help, for the lazy ones.
Message 2 of 9
(1,603 Views)
Back to LV20,
Actual problem is current loop not returning the result of loop that just finished.
It's actually saving the result from the previous loop.
250 37
260 37
270 37
280 37
290 37
0 37
10 211
20 200
30 211
40 187
50 188
60 235
70 212
80 204
90 165
100 202
110 171
120 177
130 164
140 166
150 166
160 157
170 157
180 124
190 120
200 135
210 117
220 116
230 64
240 37
250 37
260 37
270 37
280 37
290 37
0 37
10 218
20 215
30 195
40 211
50 206
Message 3 of 9
(1,547 Views)
Sorry, my laptop screen is not sufficient to efficiently debug (or even look at!) this at all:
Message 4 of 9
(1,530 Views)
mark.alexis@gmail.com wrote:
The most inner loop doesn't behave on the first iteration, .
You have a stack of six(?) huge FOR loops containing a stack of two while loops (Aztec pyramid code!).
Can you pinpoint the "loop" you are talking about and where that output is that it produces?
All you probably need is one (exactly one!) toplevel while loop and a proper state machine architecture.
Also, what is this? (just the tip of the iceberg!)
Hidden wires flowing in all directions. Aren't these just Rube Goldberg versions of simple "built arrays"? Why not use a single 1D complex array for the xy graph data?
Message 5 of 9
(1,527 Views)
You've created a huge mess.
It's not debuggable.
It's throw-away-able.
Message 6 of 9
(1,515 Views)
Refer to the code,
As others have voiced, it is unfortunately a piece of code that even the developer cannot understand or debug after some time.
Few things,
  1. use state machine or QMH
  2. abstract implementation in logical subVIs
Santhosh
Soliton Technologies
Message 7 of 9
(1,505 Views)
Back to LV20,
I put by bet on adding a shift register... That is, to fix this bug, not the underlaying problem (things are made way too complex).
But there's not really a way to see what the code is supposed to do.
Message 8 of 9
(1,450 Views)
That screams of race condition. I guess there's a bunch of local variables or Value properties spread about?
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 9
(1,440 Views)
