Firmula Node Missing Right Parenthesis
The following Formula Node code
if ( Res == "Full" )
  MS1 = 0;
  MS2 = 0;
  mcstep = 1;
Produces this error.
Error on line 1 is marked by a '#' character: "if ( Res == "Full"# ) {    MS1 = 0;   M"
Res comes from a Numeric Cntrol with Enum Properties.
It isn't obvious to me why this code produces a miiising right parenthesis error. What needs to be done to eliminate this error?
Howard
(2,596 Views)
Accepted by hrh1818
It's not complaining about the parenthesis, it's complaing about "Full".  You need to compare the number.  Of course, you could code it in LabVIEW instead of a forumla node as well.
(2,594 Views)
