Find out the size of a file?
I need to program a vi, which appends data to a text file.
The text file may not become larger that a defined size, so the vi should check the size of the file first.
How can I do this?
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
(3,099 Views)
Accepted by topic author johanneshoer
Hello Johannes, you should use the File/Directory info node in the File I/O -> Advanced File Functions palette.
Paolo
(3,095 Views)
The LabVIEW palette contains a VI for getting the size of a file, it's called 'Get File Size'
Ton
My LabVIEW Ideas
(3,092 Views)
Johannes,
you should use the File/Directory Info function found in the File IO>>Advanced palette.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,088 Views)
