Find open type definitions with specific value
I have an open-type definition used across my large vi. I want to search and locate the type definitions with a specific value, e.g. "write" or "read". Is it possible?
(1,923 Views)
Accepted by Xiang00
Two possible options:
  1. Ctrl+F. Search for the text "write". Once you get the results window, you can type to filter the results, so you could type something like "enum cons" to get the just the enum constants.
  2. If that doesn't work, you could enable VI scripting and then write your own search UI: use the Traverse for GObjects VI to find all of the instances and have specific code to find what you want (check if each found object matches the typedef, check if its value matches the value you want, etc.). This is considerably more of a pain, as you need the code to find the objects, as well as the UI and code to go through them.
___________________
Try to take over the world!
(1,913 Views)
What is an "open-type definition"?
(1,873 Views)
@tst さんは書きました:
Thank you! I will try this option. The second one would be a tough work for me.
(1,855 Views)
@altenbach さんは書きました:
Sorry, I misunderstood the name. It is just a type definition.
(1,854 Views)
@Xiang00 wrote:
@tst さんは書きました:
One important thing I forgot to mention: you will probably need to click the more options button in the find window and configure it at least not search in hidden object data, as I believe that will return results from optional values (like unselected enum values).
Just remember that these settings persist for the next time you use the find window, so you might want to change them to something that matches your generic searches after you are done with your search or you might not find things you're looking for in future searches.
___________________
(1,824 Views)
