Find a character in a string
Hi 99,
@labview99 wrote:
I am trying to turn on the  button of the array when I found one "A" in the string and I continue without knowing how to do. Can you help me please
Until now you didn't attach any VI showing your current state of progress.
How should we help when we don't know where you are?
(I prefer LV2017…)
Message 21 of 37
(1,791 Views)
Sorry,
I attach now
Message 22 of 37
(1,788 Views)
Hi 99,
your VI does not contain any array of strings, it's a simple string called "Modelo de bloque"…
Btw. why don't you use a shift register to store that value? No need for local variables!
Message 23 of 37
(1,785 Views)
yes, the array of strings is not use in this VI
Message 24 of 37
(1,781 Views)
I want to search for the letter "A" in the string and turn on the button that corresponds to the position of the letter "A"
Message 25 of 37
(1,780 Views)
Accepted by topic author labview99
Hi 99,
then all you need to know is the position of the "A" char to set a TRUE in your boolean array:
Then why do you ask about this?
Message 26 of 37
(1,778 Views)
Message 27 of 37
(1,772 Views)
Because you didn't implement all of the shown code…
Message 28 of 37
(1,769 Views)
Yes, you are right. I am so sorry I messed you up😔
Thank you so much for all your help!
Best regards
Message 29 of 37
(1,767 Views)
I have one program where I have one string separated with "-" and the I puted in  one arrayu. In my porgram the string I refer to is the "element 2"and the array "array". Now I want to find in the array if   any element of the array is the letter "P" only the letter "P".
I attach the program also
Message 30 of 37
(1,770 Views)
