Filter unwanted numbers when changing values
@crossrulz wrote:
That is a feedback node.  It holds a value and returns it the next iteration.  It works the same as a shift register.  So what Florian did is if you have an invalid number, return the previous number.
Of course this doesn't help because if you have 2 invalid numbers in a row, then the first invalid number is what gets pulled out of the feedback node.
Radio buttons are the correct answer here.  And if you want them to look like what you have now, then customize them!
Message 11 of 13
(519 Views)
Here's a cutomized Radio Button for you to use.  You can always right click and choose Advanced->Customize and put whatever boolean in there you want.
Message 12 of 13
(500 Views)
I'll use the radio buttons you provided. Thank you all very much and kudos!
Johan
Message 13 of 13
(480 Views)
