Filter string data in an array faster.
hi,
i have attached actual vi kindly go through that and suggest me for the same.
Message 11 of 14
(1,485 Views)
I did some tests, a combination of "Search/Split String" as already suggested by me earlier and a case structure that calls the "remove white-space" only in case of a match is the fastest I found so far.
EDIT: Match Pattern and/or Match regular expression should always be slower than "Split String", as long as you are looking for the exact match at the beginning of a string.
Regards, Jens
Kudos are welcome...
Message 12 of 14
(1,469 Views)
I'm assuming that there are no StringName:string element with no preceding Option element. In this case, when you find a StringName you can jump two places foreword.
Paolo
Message 13 of 14
(1,465 Views)
Thank you for your suggestion .. hope it may use full for me.
Message 14 of 14
(1,463 Views)
